Best Rear springs for a bolt on car?
Old Nov 1, 2004 | 07:24 AM
Shon Herron's Avatar
Putting a bolt on car together and have the QA1 front set up for it along with BMR K-member, and A-arms but do not have any rear springs (other than stock). I have the 12 way QA1 shocks for the rear.
What is the recommendations? Someone mentioned Ground Control 125lbs springs, but not familiar with that.....
Old Nov 1, 2004 | 09:58 AM
Stephen 87 IROC's Avatar
Re: Best Rear springs for a bolt on car?
I use V6 springs
Old Nov 1, 2004 | 06:38 PM
mod313's Avatar
And be sure to swap the V6 springs side to side. Drivers to RH and Passenger to LH. Also put an air bag in the right side spring to allow some added preload if needed.
Old Nov 2, 2004 | 04:00 AM
AL SS590 M6's Avatar
Moderator
I run stock springs with a half a coil cut off the top and an air bag in the right one.
Shocks set at 6 left 7 right.
Old Nov 2, 2004 | 04:23 PM
SAR2K's Avatar
Lightbulb Re: Best Rear springs for a bolt on car?
My set up (what I ran bolt-on & now) is stock springs all around, HAL shocks in the rear, stock shocks up front, BMR K-member w/lower A-arms, BMR adjustable pandard rod, BMR bolt on LCA relocation brackets, G2 LCAs, stock rear sway bar, no front sway bar, stock torque arm w/poly bushing.
60' times with bolt-ons were consistent 1.55 with a best of 1.53.
Hope that helps some.
Steve...
ModdedNerd
Dec 25, 2014 05:51 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
wytblur
Mar 2, 2003 03:40 PM
