Automatic Launch tec.
Old Apr 2, 2005 | 12:41 AM
HybridStorm's Avatar
Question Automatic Launch tec.
Hey guys!
I know the rear end in the 4th gen v6s (3.8L) are a lil unstable for the amount of torque the 3800 puts out...what techniques are key for a good...and SAFE automatic tranny launch so I don't blow the spider gears?
Old Apr 2, 2005 | 01:00 AM
MarkyMark's Avatar
Re: Automatic Launch tec.
brake stall it to 1000-1500 rpms and floor it.....or walk it out if traction becomes an issue.
Old Apr 2, 2005 | 11:47 PM
12secondv6's Avatar
Um, we run the same rear's in the V6's and V8's.
You shouldn't have ANY problems with the potential of 'blowing the spider gears'
Leave it in overdrive.
For that year v6... you should be able to stall the converter up to 1,800 rpm's.
Maybe we will run into each other at englishtown.
My v6.... is... not stock
Old Apr 3, 2005 | 12:12 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
aren't the spider gears only engaged when turning? to allow one wheel to spin faster than the other... without engaging the posi
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
