Anyone else's DR's wear out unevenly?
Old Nov 19, 2003 | 08:44 AM
Javier97Z28's Avatar
Moderator
Hey guys.. I've got probably 75 passes on my Nitto's and the right Nitto seems to be pretty normally worn, you can still see the pattern in the middle pretty well (about 50% worn I'd say) while my left Nitto is showing hardly any tread left in the middle, about bald dare I say.
I watch my burnouts on tape and in my mirrors when I'm burning out, I heat them up quite a bit, and they seem to be smoking evenly.
They work perfectly, I cut 1.7x 60's no problem all day long. Just wondering why one would wear out so much faster? PSI in them is identical, and they hardly have any street use. Thoughts?
Old Nov 19, 2003 | 08:59 AM
red's Avatar
red
This is the result of uneven loading of the rear end on launch and under power. Due to the torque of the drivetrain you will get more load on the left rear tire than on the right. Vise versa, this is why you see many cars pick up the left front tire while the right front is still on the ground. This will cause the left rear tire to wear more. This is why many people use air bags, or some other method, to even the load at launch.
Basically you tires are telling you that you need to adjust your suspension. I would try an air bag in the right rear coil spring to help even out the load.
Old Nov 19, 2003 | 09:32 AM
Moderator
Hey thanks for the suggestion! For right now I'm going to have my Nitto's flipped around (dismounted and remounted) to compensate for the wear, although I will follow that suggestion.
Will airbags work with the stock 4th gen springs? And if so, any ideas on how to set it up?
Old Nov 19, 2003 | 12:04 PM
Moderator
Originally posted by Steve Y
Center wear means too much pressure. Try lowering the pressure in that tire.
hmm, no I don't think that's the case here... I'm running 18psi warm.. probably bumps to about 19psi during a burnout, and like I said, both tires are even in pressure. They're not slicks so I don't want to take them any lower than 17 or 18psi.
Old Nov 19, 2003 | 01:24 PM
kevkop94TA's Avatar
I noticed the smae thing on my BFG's. Glad to see it's somewhat normal now.
Luckily they're not directional, so I can just swap the wheels to the opposite side.
Old Nov 19, 2003 | 07:19 PM
AutoRoc's Avatar
I had a left side ET Street showing some cord when the passenger side was still a full 1/16th deep and then some. Kinda felt bad..Like I didn't get my money's worth Ya know? haha
Old Jan 7, 2004 | 08:07 AM
Moderator
Just wanted to TTT this for anymore input.
Old Jan 7, 2004 | 12:17 PM
red's Avatar
red
Air bags are availiable for the 4-gen and you should be able to find them with no troubles. I don't have a part number but any speed shop should be able to look them up for you. The install is pretty easy. Once you find the pressure your car likes you will see even tire wear and should see an inprovment in you 60' times.
Old Jan 7, 2004 | 04:40 PM
Moderator
Around what pressure do you start at to test out the airbag? I have a track rental coming up and found someone with an airbag locally, so I'll be installing it tomorrow if all goes as planned.
Old Jan 7, 2004 | 08:34 PM
ULTIMTEORANGESS's Avatar
this is good info.im having the same problem.my 60' suck big time too.
Old Jan 8, 2004 | 03:09 AM
AL SS590 M6's Avatar
Moderator
I run 22 PSI in my bag.
Old Jan 8, 2004 | 07:56 AM
Moderator
That's a start.. thanks!
Anyone else?
2QUIK6
Sep 17, 2016 02:31 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
WPHIG2
Aug 27, 2015 06:37 AM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Jul 17, 2015 02:47 PM
