about how many tenths will i lose going from 3.23 to 3.73
Old May 2, 2008 | 06:58 PM
jamilz28's Avatar
about how many tenths will i lose going from 3.23 to 3.73 and how much funner is it to drive
my mods are in my sig
Old May 2, 2008 | 07:52 PM
LSWHO's Avatar
I would guess .2 ET, and much more fun... unless gas mileage is fun.
Old May 2, 2008 | 10:36 PM
bombebomb's Avatar
Ill guess .2 also. Fun to drive, Yes. I went from 2.73 so it was quite a difference for me.
Old May 3, 2008 | 07:54 AM
AL SS590 M6's Avatar
Moderator
With already having a bigger stall you won't gain much at all. Maybe a tenth.
Old May 3, 2008 | 08:48 AM
Zepher's Avatar
When my car was bone stock and an auto, I dropped .5 seconds going from 3.23 to 3.73.
Even with the stall, the gears will still help the car accelerate.
Old May 3, 2008 | 09:44 AM
rock1501's Avatar
something sounds off with that
I gained 2 tenths going from 273 to 373 when I was bolton
Old May 3, 2008 | 02:17 PM
Zepher's Avatar
Went to the track and ran a 15.7 @ 87mph, changed the rear end with a 3.73 geared rear and ran a 15.2 @ 90mph
dropped half a second and gained 3mph.
We got a similar gain on my friends 99 SS M6, 13.9 with the 3.42's, then went 13.3's with the 4.10's.
Slapped an LS6 intake, longtubes, LPE cam, valve springs, LCA Brackets and he ran a 12.03 @ 115mph
Old May 3, 2008 | 05:35 PM
Z-RATED94's Avatar
I agree. BTDT
Old May 3, 2008 | 06:29 PM
danhr's Avatar
I gained gas mileage going form 3.75's to 4.30's.
PA hill ftl
Old May 4, 2008 | 07:14 AM
Moderator
Your data is on the edge of believability.
.5 just for a gear change?
Was the weather exactly the same for both track trips before and after the gears?
And the 99 should have run the 13.30s stock.
With my setup when I went from 3.42 to 4.10 I only gain about a tenth average.
Old May 4, 2008 | 12:15 PM
CamaroRacing12's Avatar
yea a half of a second is a huge gain, i mean it could happen but very unlikely, i bet its more towards .2 tenths
Old May 4, 2008 | 12:38 PM
LSWHO's Avatar
My brother and I race each other all the time. He has a 96 formula and I have a 97 ta. Every time we do mods we race each other to see what they did compared to the other car.
He had 3.23s I had 2.73s. From a dig it would be ok for me since I had traction, but by the end of the 1/4 he had pulled a couple cars. From a roll he'd immediately pull and keep going.
When I switched to 3.42s I would pull a 1/2 car and then pull a full car or two by the end of the 1/4.
(through both of these runs I had an intake, in the second run I also had a tune.)
Old May 4, 2008 | 07:20 PM
tomcowle's Avatar
I can buy that it gained that much from a gear change especially if the car had a decent convertor in it already. Torque multiplication is something a simple formula can't figure out.
I went from a 13.07 to a 12.09 with a 3.42 to 3.73 gear change and a 2800 stall to a 3000 stall, how did that work? This year I had a convertor built for my car and I'm making another small gear change, I'm hoping for another 4 tenths.
Old May 5, 2008 | 01:58 AM
Zepher's Avatar
Weather was pretty much the same for both trips with both cars.
The 99 was driven by myself and by my friend who is the owner.
With the stock gears, we could only get a 13.9 out of the car.
did the gears got a 13.3. this was about 4 years ago.
At the same track last year, I was able to get my friends bone stock 02 WS6 to run a 13.12 @ 109. I probably could have hit a high 12 if they didn't close the track early. I did 3 passes and my first time ever driving that car was going from the staging lane to the tree.
I also had my Formula with me and it had a T5 and 4.10 gears (4.10's are fun but way too much gear for a daily driven car with a .78 OD).
I got a 15.2 @ 93 out of it. My ET didn't change from the Auto/3.73 but I did pick up 3mph with the T5/4.10's.
I grenaded the 4.10's a year ago and am now running with 3.42's.
Old May 5, 2008 | 06:11 AM
Moderator
Kind of irrelevant to this conversation. As long as you make 2 changes at a time you really can't prove how much each item effectled the et difference.
It's just like the guys with stick cars above. What a gear change does for a manual car and what the same gear change will do for a auto that already has a higher than stock stall is apples and oranges.
