88notch
88notch
Anyone wanna take a guess what a 88 notch thats been stripped pretty hard 8 point bar,Upper and lower control arms,3.73's,Subframes,Bcam,GT40 intake with 80mm TB,headers and its a 5speed.Any guess what this car might run?
Re: 88notch
I had a friend with a similar car except probably a little lighter. The engine was stock 302 shortblock, Holley system max kit:heads/cam, headers, 4.30's and 26x10 ET drags. He ran 11.90's@112mph N/A on a good day and 11.00's@121mph on 175HP NX and the gear was too low for n2o and the stock ECM. later Clint
Re: 88notch
In my mustang experiences, for every good running mustang combo there are 10 heads/cam/intake cars that can't get out of the 13's. I say get to the track and get a baseline.
Also 3050 is pretty heavy for a stripped Notch.
Re: 88notch
Originally Posted by camarolover20
It was like 3,050 with a aftermarket subframe but now bac 2 stock.The TB is what I got with the car is use 2 be a charged car so going to use it see how it works for now.
Depending on your driving skills, the fact that it's presumably on stock tires puts it anywhere in the 13-15 second range. Best way to find out is to make some passes with it. We all gotta start out somewhere.
Re: 88notch
Is the T5 stock? Slick tires will be hard on it. The old LX I ran had about 30 passes on it (10 on the track 20+ on the street) with a 28"x10.5 ET STreet throwing anywhere from a 200 to a 275-shot at it. The transmission chattered so bad, it sounded like I had rocks under my seat.
Best of luck. The Fox-body cars are easy to make fast, especially when you can run a 200-shot on the factory motor all day long.
.The car will be runin mild ported heads in the next few months.
