60ft Improvements
Old Aug 26, 2007 | 11:26 AM
  #16
Fuels94TA's Avatar
Originally Posted by AL SS590 M6
Do you run ET street radials? Or ET streets? They are 2 completely different tires and ET streets like about 15.5-16 PSI warm on an average weight f-body. ET street radials should like closer to 20-22. I run Hoosiers new drag radial and I dead hook 1.47 to 1.49 60's at 21 PSI hot.
Your right I didn't note on camaroracing post he used radials. I'm running ET Streets... Camaroracing maybe drop your psi down to 18.5-19 before your burn out. after your burn out the psi will rasie to about 20psi.
Vinny
Old Aug 26, 2007 | 11:30 AM
  #17
CamaroRacing12's Avatar
yea im goin back wed prolly... i will try that thx but i doubt it will fix my problem
Old Aug 26, 2007 | 11:37 AM
  #18
Fuels94TA's Avatar
Don't give up...Just give it try. I was stuck at 1.7 60ft for a long time. That was at when I had my psi set at 16 before my burn out. Then when I return back into the pits I would check my tires they where at 18-18.5psi. I started to drop them at 14 before my burn out and now I'm hitting 1.6's
Vinny
Old Aug 26, 2007 | 06:28 PM
  #19
so drop em to like 17-18 cold?
Old Aug 26, 2007 | 06:41 PM
  #20
Fuels94TA's Avatar
Yes, start it it off with 18.5psi, then when you return into the pits just check to see how much it rasied the tire psi. From there you can play around on what works for you.
Vinny
NewsBot
Sep 14, 2015 08:50 AM
CARiD
Sep 7, 2015 08:21 AM
nd4spd200
Aug 21, 2015 09:30 AM
karpetcm
Aug 14, 2015 03:02 PM
Boss002
Jul 9, 2015 03:33 PM
