26" or 28" Tire/Which One
Just curious on what people on the boards recc. should i use a 26 or 28 slick
Car has 353/369rwp a 12bolt w 4:11's car is a m6 car all tubular suspension upfront--viking double adjustable w 300# springs---- Ive read alot of posts and its always 50/50 lol. Just curious as to what most people are running--
Re: 26" or 28" Tire/Which One
Stick cars can be difficult but I would try 26" set at 22psi first. The 26" and 4.10s are a great match whereas the 28" will take the ratio down a notch unless you are using Nitrous which will be a benefit
Sent from my LG-P999 using Tapatalk 2
You keep posting this same info, and I believe it is wrong. I explained that in your post on the "Wheels & Tires" forum, where you indicated you fit a 295/60-16 on your car with no problems.
https://www.camaroz28.com/forums/whe...99-z28-878399/
A 295/60-16 IS A 30" DIAMETER TIRE. You are not putting a 30" tire on a 4th Gen F-Body without some body work.
In the PM you sent me, you told me you were buying:
I suspect what you have is the M/T Drag Radial II, in sixe 295/50-16. That is a 27.7" tire, at least according to M/T.
Originally Posted by Mr99SS
will MT drag radial 295/50/16's fit on the stock tires and not hit the lip bad ? The car has......
It all depends on what you are doing.
Obviously you aren't racing or you would have an auto.
With a manual you need much more traction at the line but you don't want you break stuff either.
I have been told for the last 66 years of my life that if you spin at the line you need to go back and either reduce timing or tire pressure until it doesn't.
