2 steps on LT1 6-speed cars
Old Sep 1, 2006 | 10:47 AM
  #16
Sweetred95ta's Avatar
Re: 2 steps on LT1 6-speed cars
Originally Posted by TQdrivenws6
To test where the activation point would be, just put the car in neutral, turn the key to the start position and slowly push the clutch in. When the car turns over, that is where the switch activates.
I don't have that hooked up (from doing the A4 to M6) swap. I do have a digital 6 and have been trying to figure out how to use the 2 step. I may hook it up so that I can use it.
Old May 27, 2007 | 10:33 AM
  #17
Kevin97ss's Avatar
Just to add some info to the archives..... I set up a launch/power shift limiter using just the MSD soft touch rev control module and a variable resistance chip (1k-12k rpm) wired to the cruise clutch switch through a relay. I did it this way because I did not want to use an ignition amplifier. I just set the chip to the rpm I want to launch at (5000 rpm) and it will shut down the motor between WOT shifts when the clutch is kicked. Using the cruise switch means the pedal only needs to tavel about 3/4-1 in before the limiter is on.
Kevin
onefastgta
Mar 19, 2015 10:10 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
