2 step
Old Aug 1, 2006 | 08:04 AM
JS02's Avatar
2 step
I have a 97 SS M6 that I have put in an MSD. I want to put in a switch to use a two step rev limiter to help with launches. What do you recommend to use for a switch to operate it with a six speed?
97SSM6
Old Aug 1, 2006 | 02:17 PM
95Bird's Avatar
Re: 2 step
I have mine on a microswitch on my clutch pedal. When clutch is on the floor the two step is activated. I never hit it between shifts as I don't activate the clutch that far down on normal shifting. Here is a schematic(sp) of how to hook up a clutch activated 2 step with a nitrous setup if anyone is interested. I didn't do it..just hosted it for someone that needed it.
http://www.ipsb.net/herringt/two-step.jpg
Old Aug 1, 2006 | 02:38 PM
JS02's Avatar
Re: 2 step
Thanks for the info. I might go that way. Do you think it hurts your reaction time if you keep the clutch all the way to the floor until you launch?
97SS M6
Old Aug 1, 2006 | 03:12 PM
95Bird's Avatar
Re: 2 step
IF it hurts any I've learned to adjust to it. Plus..I just dump the clutch. That helps alot since I don't have to find the slipping point. I just drop the hammer and let er eat. My reaction times are usually pretty good when I'm trying to get on the tree.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
WobblySausage
Oct 7, 2015 02:44 PM
Bxlt1
Sep 17, 2015 08:31 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
