13.73 ???? Is this bad ???
Hey guys , its me again and trying to get an opinion. Heres my slip
60ft - 1.986
330ft- 5.688
1/8th - 8.781
1/8thmph- 79.42
1/4- 13.731
mph - 99.73
this is after my pcmforless tune , 3000 tci stall , and 3.73's on a pair of fulda extremo rubbers. I know a big part of it was driving (I had to roll into it SLOW to keep from spinning halfway down the track which I did the first time and burned rubber on my way to an astounding 14.8)). I just wanna know if theres a chance my car isnt making the power it should. Is the 1/8th to quarter difference good ??? How about the mph ??? Anyone with similar setups let me know what you ran and what tires you used . These times were taken at richmond dragway , the 1st time I ever raced the quarter and second time Ive raced this car anywhere.Any recommendations on launching this beast with street tires would be appreciated as well.
thanks , Justin
60ft - 1.986
330ft- 5.688
1/8th - 8.781
1/8thmph- 79.42
1/4- 13.731
mph - 99.73
thanks , Justin
Re: 13.73 ???? Is this bad ???
No headers? That is probably why the mph is so low. The 1994's had a lot of restriction in the stock exhaust.
Were you spinning a lot? If so some drag radials should fix that problem.
It is almost impossible to quantify your actual performance if the power was not getting to the ground and some altitude reading would also help.
Certainly your perfomance is not "bad". The object is to have a good time and see what the car will do. Good tires and some headers should help a whole lot.
Dude, if your running an aftermarket converter, you must get DRs of some sort to get the most out of the combo.My time in sig is with a PI2800, 3.23s, DRs and a 1.85 60 ft. you should be down around there with more traction.BTW I don't have headers; just a cutout.
I have slp midlength headers , I did autotap the car tonight and found a couple of interesting things , got a code 400 which say EGR System , dont know whats wrong with it but thats what I got . Also noticed the fuel trims were unever but both negative -3% and -14% or so , I have the fuel pressure cranked up to 46lbs I was wondering if that might be a prob , car is stock. Any more help would be great , thanks.
Is this in the 97 with the headers and hot-cam too. If it is you really need to get dr's so we can see what it can do. Your mph looks really low for the kind of power you should be making. My though is that the stall and gears is basically doing nothing for you because you can get that good launch off the line. Your times would really improve with dr's.
I concur with the drag radials. It is hard to diagnose performance when the car isn't hooking up. The mph seems way low but without hooking up there is no way to quantify it.
I was thinking about drag radials , just worried about breaking my gears again , with stock gears and stall I still managed to rip every tooth off the pinion gear. Putting the tranny in the car really set me back , if I break my rear again its gonna be off the road for a while
Get some used drag radials and they'll help alot! A used 10 bolt is cheap, I just sold one for $200, if it goes get a M-6 rear with 3:42's :-)
Have you checked out easternfbody.com? Lots of us run at VMP, it is a better track then Richmond. You'll get better times there too!
Ed
Ed
i am not sure if u all noticed but he had a 1.9 60'. that is damn good for street tires. that means he was not spinning much at all. how much more are the drag radials gonna do for him, a 1.8 60' i dont see that lil bit in the 60 xplain y his times are bad!
yeah but I wasnt spinning on that run because I eased into the trottle then punched it after I was moving , Ive got alot more 60 foot I can skim off if I can get the thing to hook up
Your bad time isn't because of your 60'. Actually i'm not sure if i've ever see someone get under 2.0 with street tires! I'm trapping the same as you. Your car can't be running right with a hotcam and headers you should be very low 13's!
TONY
TONY
TONY
TONY
. thanks , justin
p.s. oh yeah mark , theres not a stock piece on my motor besides the shortblock , maf , injectors , and fuel rails.
I was having an EGR code when i got my car too. But when i got my pcm tuned i had that code turned off. Doesn't seem to affect performance.
TONY
TONY
. Right now the car has a backwards welded muffler on it right now (the guy was trying to quiet it down and it is rather quiet, the pipe is welded into one of the exit pipes using a reducer 3" to 2.5" drop
) . I dont think a backwards welded chambered muffler is doing the car any good either especially with that 2.5" reduction at the muffler. I cant wait for my loudmouth to go on finally
. Ill let yall know if that helps any as I might be going to the 1/8th near here on friday. thanks , Justin
