10.06@133.72 n/a 1.40 60ft. footbraking
Old Nov 3, 2002 | 08:16 PM
Joseph Overton's Avatar
topic says it all ...lets just say it was a good day...can't wait to let loose on the t-brake..but 9's footbraking is definately in the cards.. heres best slip of day
1.402 60ft.
6.394@107.19
10.06@133.72
Old Nov 3, 2002 | 08:41 PM
RacinLT1's Avatar
Joe that thing is Flying...2 days and already that close to 9's footbraking it.
Good luck,and Cya on the 16th.
Old Nov 3, 2002 | 10:27 PM
Jason Short's Avatar
Joe, that is just amazing! Congrats man.....unreal!
Can you elaborate on your combo? Are you still using an LTx intake manifold?
Jason
Old Nov 3, 2002 | 11:31 PM
Nostang 96z's Avatar
Wow...great times....I can't wait to see that car run in person. Congrats
Matt
Old Nov 4, 2002 | 01:32 AM
rskrause's Avatar
Moderator
Joseph: 10.06 was all motor?
It looks like you will be needing a cage soon, right?
Rich Krause
Old Nov 4, 2002 | 09:32 AM
RK full cage is already in also that day got my 3 passes in for my liscense.. 388 c.i. 12.8:1 solid roller all motor.. I'm using a converted carb intake to FI.
Old Nov 4, 2002 | 10:46 AM
95Bird's Avatar
Wow..thats awesome man. Its awesome seeing the lt1 market/racers step it up to compete with the ls1 cars. I love it
Tim
Old Nov 4, 2002 | 12:10 PM
Thanks for the info Joe.....what intake did you use (vic jr., brodix, holley, other)? Also, are you using a 4 blade (carb style) throttle body or stock style? I am going to do a vic jr. conversion on my setup (FI) this winter.
Thanks for any info
Jason
Old Nov 4, 2002 | 12:20 PM
KTamez's Avatar
Joe,
Is this IHRA? It takes I believe 6 passes in the NHRA, and along with that you have to run 2-3 all out 9 second passes to get the license.
Congrats Nonetheless! Are you still planning on using the Dry N20 at a later date?
Old Nov 4, 2002 | 12:33 PM
Daddyo's Avatar
I was also wondering what intake you used? As I plan on doing the same thing this winter. And post some pics of your set-up. Should be 9's no problem, good luck.
Old Nov 4, 2002 | 12:38 PM
Kurt yes its Ihra and 2 6.49 or quicker in the 1/8 applies even though they were 10.0 passes.. though the gas isn;'t on the car yet. I do however have the intaked tapped for the fogger and all the lines prebent to make it easy to throw on when the time is right,, Since its hard to tune for n/a with a larger injector to compensate for a large shot..I chose to go with a fogger this time to get the best of both worlds and alot better cylinder to cylinder tuning...
I'm running a lingenfelter design accell intake and 4 blade 1200 cfm tb with some work done to it ..its flowing around 1350 or so now..
Old Nov 4, 2002 | 05:22 PM
squinn's Avatar
Joe thats great, what is your race weight and what head are you running?
Old Nov 4, 2002 | 06:43 PM
kevkop94TA's Avatar
Thumbs up
Old Nov 4, 2002 | 06:52 PM
Steve not quite sure still need to scale it but I beleive around 3200 or so with me in it..I still have factory carpeting and its a t-top car..plus the front half of cage I added ,put back some of the weight I pulled.... I'm running a afr227 head big runner volume ,so I was kind of undershifting the car at 6800,which is what i shifted at last year just to get a base line comparison ...Gonna move shift points up some this week and take advantage of all that air that these heads can actually flow.This motor will spin 8g easily so I have to see where it likes it ..only so many runs in a day to find out what it likes let alone get all the fuel and timing tables right at the same time.. But thanks for the reply..Your car isnt no slouch either..
Old Nov 4, 2002 | 09:05 PM
What are the specs on the cam you are running Joe (if you dont mind my asking)? Also, what fuel?
Also, I tried sending you an email but it came back undeliverable??
Thanks!
Jason
