1/8 mile to 1/4 mile time estimates?
I have heard of a lot of people talkin about figuring out there 1/4 mile time based on their 1/8 mile time. What is the formula for converting a 1/8 mile time to a 1/4 mile time? Or is there a website that does that calculation for you?
Re: 1/8 mile to 1/4 mile time estimates?
I think 1.55 is alittle generous unless you have a stick car. I think 1.57-1.58 is more realistic, especially if the car has a pretty big converter.
Randy
Randy
thanks for the replies.. just for anyone reading this, I also posted on this question on a couple other forums and got these websites (that both seem to give the same result for conversion):
http://www.tciauto.com/tech_info/calculators.htm#2
http://www.wallaceracing.com/eigth-t...conversion.php
There is no exact formula but I've always used 1.56 as the conversion number.
I just grabbed one of my old timeslips to see. It was a time trial run so the runs were flat out.
1/8 mile = 6.556
1/4 mile = 10.175
6.556 x 1.56 = 10.227
My opponent ran 5.733 and 8.958
5.733 x 1.56 = 8.994
The only way to know exactly what your 1/4 mile time will be is to actually run on the 1/4 mile. There are too many factors that can change that time.
1/8 mile = 6.556
1/4 mile = 10.175
1.56 is a commonly accepted factor for this conversion. The NHRA uses a factor of 1.60 ...I guess because it is a conservative factor for them. NHRA likes the 1/4 mile IMHO.
Vince
Vince
Vince
Vince
Originally Posted by The Engineer
The basic assumption on this issue and the math used is that most cars make 64 percent of their ET in the first 660ft, or 1/8 mile. Therefore, the number 1.5625 is derived by dividing 0.64 (64 percent) into 1. And, this method (1/8 ET x 1.5625) is a very accurate way to determine possible ¼ ETs using the 1/8 ET as a baseline.
1/4 mile ET=(1/8 mile ET + .22)/.655 come from then? I've seen that on a few websites for the formula used for the online calculators, seems to end up with really close to the same result..
NHRA also uses the 64 percent theory for their 1/8 mile and 1/4 mile ET class indexes. Again, this formula will provide a "good indication" of your possible 1/4 mile ET, based on the 1/8 mile. And, that was the context of the basic question, how to convert 1/8s to 1/4s (an estimate).
Additionally, I also checked the math using my friend's big-block N/A dragster that runs 7.90 to 8.10 in the 1/4 to see if that type vehicle would be different. The dragster 1/8 mile ET was "very close" to 64 percent of the 1/4.
So, the math does work and you can use it to make a "very close" determination!
jb4xx
Feb 2, 2015 10:00 PM
centric
Aug 15, 2002 09:04 PM
