XP and datamaster
XP and datamaster
Friend bought a Dell 233 mhz laptop with 128 ram I has XP on it and when he tries to install Datamaster it says insuficent memory. Will Datamaster work with XP?
I run datamaster on XP just fine. The problem is your laptop and xp...
Here are the requirements for XP to run properly:
*PC with 300 megahertz (MHz) or higher processor clock speed recommended; 233-MHz minimum required; Intel Pentium/Celeron family, AMD K6/Athlon/Duron family, or compatible processor recommended
*128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
*1.5 gigabyte (GB) of available hard disk space.
As you can see your laptop falls short on processor and barely covers the minimum on memory.
If I were you I'd load up Win98se on there and you'd be better off...
Bails098
Aug 17, 2015 05:15 PM
Dave69Z
Apr 23, 2003 12:07 AM
