Wideband o2
Old Sep 25, 2005 | 09:49 PM
Honda Hunter's Avatar
Wideband o2
Do they have any wideband setups that will plug into my laptop? Looking for something on a budget and dont need anything super fancy, just something I can plug into my laptop when ever I need my a/f throughtout the powerband.
Old Sep 25, 2005 | 11:32 PM
LWillmann's Avatar
Re: Wideband o2
There are some that have a programmable output that can send a stock style narrowband signal. You could use that output to feed the PCM and log it.
SOme people have also used I think the a/c pressure sensor for logging a 0-5v wideband.
And some widebands, like my Dynojet Wideband Commander have logging capabilities built in with internal memory. Start it logging, and it will log the TPS and RPM along with the wideband readings, then you can compare the values to the one you logged with the laptop.
And some other widebands have an output that you can hook directly to the interface cable for some readers/scanners. I don't think there are any for the 93-97 cars though.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Aug 4, 2015 09:32 AM
95Blackhawk
44
Nov 10, 2010 03:11 PM
InjectedSS
Aug 21, 2003 01:01 PM
96speed
May 27, 2003 08:37 AM
