Who fixes pcms and what caused this?
Old Jan 24, 2004 | 11:48 AM
slimdawson's Avatar
This is the first time I have fried a pcm. I was using Tunercat and it stopped shortly after I started it. It said something like invalid response from pcm. All, I know is, it isn't working. The pump comes on for about 1/4 of time it used to and the fans immediately come on. I can't read the pcm and it won't crank.
My next question is, who fixes them? I thought Andrew use to but does he anymore?
Thanks.
Old Jan 24, 2004 | 12:13 PM
slimdawson's Avatar
I think it also said something like disk write error.
Old Jan 24, 2004 | 05:01 PM
turbo_Z's Avatar
I know Ion aka madwolf will fix it for a reasonable cost and in a reasonable time frame.
Have you used the same procedure to program the PCM every time or did you try something new or different this time?
Old Jan 24, 2004 | 11:56 PM
slimdawson's Avatar
The only thing I did different was download a file from bfranker's site. I had to convert it to a .bin file from .lt1 file. I then modified it and tried to load it.
My laptop's A drive is not working too good so I am wondering if there may be a problem with my laptop which caused the error during programming.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
Alex Barnes
Jan 24, 2015 10:21 PM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
