Where to start programming with Headers
Old Jul 13, 2004 | 12:25 PM
thermwood1's Avatar
I will be installing headers in the next week. I just converted from OBD2 to OBD1 and have a long way to go for learning Tunercat. I am using a stock 95 bin file now. I was wanting to see what adjusts should be made for the header install, or at least a starting point. Thanks.
Old Jul 13, 2004 | 07:00 PM
texanmutt's Avatar
You can adjust the VE tables smiply by using the blms as a referance or by using ve master which does the same thing automaticly. This will only be good for part throttle tuning though. To tune for full throttle you will need a wideband o2 sensor kit to adjust the PE tables (%change to AFR in WOT vs RPM table in tunercat).
Noenav
Mar 1, 2019 07:38 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
guionM
14
Jun 19, 2002 08:30 AM
