What is the signs of a dying computer
Old Oct 20, 2007 | 04:55 PM
mrmint69's Avatar
I have read about the computer going bad and causing problems. How can you verify this? Does the whole thing work incorrectly or just certain things? Can it appear to be working fine on almost everything but not on others? I have been chasing gremlins since i bought the car and i have Freescan and it appears it is fine but things like the knock retard are not showing to be working. I will check the sensor but its in a bad spot so it will be a few days.
Old Oct 21, 2007 | 06:00 PM
Kevin Blown 95 TA's Avatar
Most of your problems are in bad connections or wiring. Also bad grounds cause a lot of probs. Your PCM is pretty robust.
Old Oct 22, 2007 | 06:45 AM
Maybe the retard has been tuned out. Have you looked at the programming?
PCMs rarely go bad.
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
