what a/f ratio ??????
Old Mar 8, 2005 | 06:18 PM
slowZ's Avatar
Question what a/f ratio ??????
what a/f ratio do tuners shoot for, my car has a 355, lt4 h/c kit, shortys, loudmouth and some other little things. i dont think my tuner is doing it right cause on the dyno the a/f was 12.8/1 and he wanted it at 12.3/1. isnt that pretty rich?
Old Mar 8, 2005 | 06:46 PM
tx_lt1's Avatar
Re: what a/f ratio ??????
considering stock is like 11.5:1, I'd say anywhere between 12.5-12.8 would be right. But if you make more power at 12.3:1, then you should run 12.3:1. You should base your a/f off of what makes the most power.
Old Mar 8, 2005 | 07:31 PM
slowZ's Avatar
i thought stock a/f was around mid 14:1 and doesn't other tuners on here shoot for something like 14.7:1 for best performance
Old Mar 8, 2005 | 07:48 PM
Doc99SS's Avatar
Part throotle AFR is 14.7, that is called "stoic".
Lean best torque is 13.0,,, best power is 12.6. So 12.8 sounds real good. I think that you want to run as close to 13.0 as you can get it without detonation. If you get KR, then run a bit richer and/or back off the timing.
If you are at 12.8 AFR (with a wide band O2 meter) without KR, then leave it alone, you are about perfect.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
Henson071
Dec 30, 2015 09:55 PM
Z Power
Sep 19, 2015 11:19 PM
Henson071
Aug 4, 2015 09:32 AM
