What does Hypertech tuning do actually?
Old Jan 16, 2009 | 09:21 PM
madhatter's Avatar
I have used it for my fans and gears in the past. I got the unit for free. My question is what does the power tune effect? Does it lean it out? Timing? I don't have a dyno to test before and after, and I am not going to do a full tune until the engine goes in later this year. I figured I might as well use it since I have it.
Sean
Old Jan 18, 2009 | 09:21 PM
Kevin Blown 95 TA's Avatar
I looked at that one time and they lean it out mostly in the higher rpms. I dont think they did much, if anything to the timing. Not sure if anything has changed since then.
Old Jan 18, 2009 | 09:31 PM
sn8ke eatr's Avatar
pretty sure it just leans out your a/f.
personally if the car is stock i wouldn't foresee a problem but once you start messing with the motor, especially internally, id ditch that thing asap and get a real tune. oh and fear and loathing= the **** haha
Old Feb 11, 2009 | 10:48 PM
vettedoctor's Avatar
not much i pulled a ecm with a hypertec tune car was faster when i was done. compared to stock they have a very very strange fuel curve like 15 to 1 at 800 rpm with wot
Old Feb 17, 2009 | 09:30 PM
'97 30th Anniversary Z/28's Avatar
I thought they stopped the car from rolling forward when you jacked up the rear.
colts0455
Sep 4, 2015 01:41 PM
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
