VSS Diagnostic question
The older version of TC that I used to use, had a table for setting VSS Diagnostic enable by rpm. This new version doesn't
However, I see 2 switches for VSS diagnostics in the switch table. Is turning them off the same as setting the rpm to > 3000 to keep from going into limp home mode with a higher stall converter?
squarehead
Jan 15, 2015 07:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
