VE Tables And Air Fuel Ratio?
Old Oct 6, 2004 | 09:01 PM
  #16
97Z-M6's Avatar
Re: VE Tables And Air Fuel Ratio?
Originally Posted by Dan K
I did this on my car and it didn't change a thing.
I did it on a buddies car, and it did work.
were they same year cars
Old Oct 7, 2004 | 12:47 PM
  #17
95Blackhawk's Avatar
Originally Posted by 97Z-M6
huh i have news for you they are used on a maf car when the maf IS working properly.
scan your car and record the blms the up your ve tbales by 10% and your blms will go up roughly 7 points.
everybody was saying they arent used so i decided to find out myself and are referenced.
I come to my stated conclusion based upon my own programming experience. Yes, did your test long ago. My BLM's have always reverted back to their original numbers after adjusting VE tables. If it is something specific to yours, I would say...fascinating.
However, what reason would a MAF car use VE tables? VE tables are only assumptions that do not change and inherently cannot be as accurate as a MAF. If they did use both, there would be conflicts.
Ben
Old Oct 7, 2004 | 04:10 PM
  #18
quicksilver97ta's Avatar
"scan your car and record the blms the up your ve tbales by 10% and your blms will go up roughly 7 points."
Hey I'll try it, Dan said it affected his freinds car also. But it's still got to be a matter of tunning preference. Dan has a point about leveling out the VE tables in the WOT range, as I see no advantage to tunning the VE table. VE cars are more sensitve to weather so there could actually be a disadvange if your not prepared to compensate.
But the whole idea of an MAF working simultaniously with the VE tables lacks any explanation of how that works.
Old Oct 8, 2004 | 12:12 AM
  #19
Dan K's Avatar
No, but they were both OBD I computer cars with a functional maf so it shouldn't matter.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97ss1826
Mar 13, 2003 11:58 AM
Burn_Out
Aug 18, 2002 08:49 AM
