VE Master
Old Mar 10, 2003 | 08:48 PM
  #16
jgeorger's Avatar
Originally posted by The Highlander
How can that be possible??? I thought cell 16 was idle only...
As I see it you use the map vs rpm and not the cell itself... you use the cell to make the average... but when you are going to apply the changes the ve table doesn't relate whatsoever to blm cell, but map and kpa.. in that case my recommendation is to:
Weigh it using hits... if you hit 30 on one cell and 70 on the other.. the average x the proportion.. or something like that?
With that wild example you will only make one richer and the other one leaner!! I dont think you can be like that or something... .
Try to weigh it against the most cell hits...
Say your car idles at 1000 rpm and 50 kPa. In that case your cell 16 data "overlaps" cells 5 and 9. The VE table is indexed on map and rpm, so you can figure out what fuel trim cells cover which VE cells. My dilemma was how to integrate cells 5 and 9 with 16. So what do we prefer to get right? Idle, or part throttle cruising? Yeah it's okay if the blm's are similar, but if they're not and you lean the idle out, you might be making the car too lean for driving.
Weighing on hits is probably not the best idea, since it takes into consideration how the data was logged, and usually that means more 16 while you're setting up the laptop and such.
Hell, it's very easy to adjust the ve manually at idle It should only involve a few VE cells. I'm gonna do some more thinking on this.
Old Mar 10, 2003 | 10:41 PM
  #17
Dan K's Avatar
I'm not sure why this is turning into such a big deal?
If you're screwing with the VE table in order to lean out your idle it should have very little effect on part throttle. Think about what rpm your at while idling.
Do what Joe says and just note what rpm and map the idle is at and adjust that cell, and some adjacent ones, manually. Easy as that.
VEMaster shouldn't need to do this for you.
Joe, I would like to see you leave the program the way it is now. I don't see a need for it to incorporate cell 16 at all when any adjustment needed for idle can be made manually pretty easily.
Unless I'm missing something?
Old Mar 11, 2003 | 06:42 PM
  #18
jgeorger's Avatar
Dan,
I'm with you on this one. I was pretty tired last night and maybe not thinking too clearly. I will leave the program alone.... I'm behind in requests to port it to other ecms anyway.....
Joe
Old Mar 11, 2003 | 07:51 PM
  #19
Highlander's Avatar
ls1????
Old Mar 11, 2003 | 08:20 PM
  #20
jgeorger's Avatar
ls1????
No, older GM speed density ecm's. I seriously doubt there will be any VEMaster for any OBD-II pcm's because that version of LT1Edit and LS1Edit have the binary files scrambled, and it's just not worth the extra hassle for a maf-based pcm. Plus the OBD-II datastream isn't fixed, so that makes parsing the logfile a little more challenging. Assuming the user also chose to log the necessary parameters.
Old Mar 19, 2003 | 04:36 PM
  #21
tjwong's Avatar
Joe,
I have used your VE Master with very good results. As you have mentioned in an earlier post that there are mixed thoughts on whether it works with a PCM operating in closed loop and using a MAF sensor.
I have tuned several cars, mostly 94/95 Corvettes and a couple F bodies with cams from a small ACCEL/LPE 211/219 cam to a CC306 cam. All of which worked well after using your VE Master. I don't beleive that GM installed the VE tables into the workings of the PCM as just a fail safe limp mode home incase of MAF failure. Or just for open loop operation in the interim time before the PCM switches to closed loop. I am sure that the tables are used for much more than what many of us think.
I know of a couple pro tuners that had manipulated the VE tables for cam tuning as well, long before you came out with VE Master for the OBD1 cars. I know t heres a lot of argument out there over this one subject, especially on the LT1 edit lists. But I for one and few of my buddys swear by it.
Keep up the great work!
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
