Upload/download files
Old Aug 10, 2002 | 09:47 AM
1BadBrd's Avatar
Post Upload/download files
I final got the damn thing to run right, but when i want to program the PCm with the file i see on my screen how do i do that now. Do i have to upload the PCM and then download the new file. If so what do i need to do to do the download.
How do i start the download process. I know i turn the key to the on position, then what do i do.
97 TA, P&P LT1 intake, P&P LT1 heads w/2.00"I 1.55"E,LT4 HotCam Kit, MAC header, Random Tech. cat.,Borla Exhaust, Ported MAF, 52mm TB, 30# Accell injectors, Ed Wright program, Electric Waterpump, CAI, 3:42 rear gears, f.p.r,255lph fuel pump,
[This message has been edited by 1BadBrd (edited August 10, 2002).]
Old Aug 10, 2002 | 04:01 PM
Hal Fisher's Avatar
Post
I don't know what file your looking at or if its correct at all. But, you should maybe download the file from your car first then download the new file. Normally, you don;t have to download the file first.
If you have a stock odb2 then the only way is lt1 edit. If you change to an odb1 then its much cheaper to use tuner cat.
Hal
Old Aug 11, 2002 | 11:10 AM
Dr.Mudge's Avatar
Post
Hal, does this mean your Tunercat FLSH woes are solved? I remember you mentioned some months ago some laptop of yours just didn't like TC...
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
