tuning help blinking ses
Old Feb 6, 2007 | 03:37 PM
bubba24's Avatar
alright just tuned my 95 lt1 pcm used tunercat winflash all went well I read and then took the bin and editied and removed the egr and air flags. Saved the bin then used tunercat winflash and programed the pcm. But now the fans just come on and the ses light just rapidly blinks. What gives?? Is the pcm screwed now? There was no errors that popped up when programming.
thanks for any help
Old Feb 6, 2007 | 05:16 PM
sreve's Avatar
are you saying it does not run? or it starts with the fans and a blinking ses?
Old Feb 6, 2007 | 05:54 PM
bubba24's Avatar
it will start and run for about a sec then shut off. But the ses light blinks fast and the fans run with the ignition on. I pull the pcm batt fuse and it all turns off. Or if I pull the fans fuse the fans turn off but that ses lights looks like it dim and blinking rapidly.
Old Feb 7, 2007 | 05:20 PM
sreve's Avatar
so you just turned off the diagnostics in the switch table? did you turn off crank air? (i don't know what that is) as air pump runs in open loop only. there is a flag for the air pump and two for the egr. to disable the system though you need to go into constants and change the values too something where it can't possibly run ie: enable egr coolant temp, say 150c. obviously it has a problem a blinking ses is to alert you to cat damage is in your future. misfires will trigger this and vacuum leaks at low throttle, idle can cause misfire. the egr being open would be a big one and could cause a starting problem if it is open. unplug it and see if this helps.
Old Feb 7, 2007 | 08:07 PM
jay_lt4's Avatar
im thinking you fried the pcm
Old Feb 7, 2007 | 11:16 PM
Try putting it back like it was and see if it works.
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
CARiD
Jul 7, 2015 08:19 AM
