tuning a bolt on car
Old Feb 20, 2004 | 12:57 PM
Prorac1's Avatar
I have a 94 z28 with the bolt ons listed in my sig, plus 1.6 rr and 3.73 gears. I have data master and tuner cat, but havent done much with them yet. Is there any thing in perticular i should play with to start off that would be beneficial to a bolt on car? Fuel pressure, timing curves, etc. Thanks Prorac1
Old Feb 20, 2004 | 11:28 PM
Hal Fisher's Avatar
Well set it up for the right gears so everything is correct (rpm, mph, od).
You could increase the timing a bit in the higher map settings. Of course the higher you go the better the gas you should run to reduce knock. Thats what hypertech does.
Hal
Old Feb 22, 2004 | 01:10 AM
97Z-M6's Avatar
the pcm does not control fuel pressure.
my advice would be start everything on this board.
97SSdude
Dec 31, 2014 07:43 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
