Tuning for 4k stall.
Old Nov 2, 2010 | 04:57 PM
jpack24's Avatar
Yes I have read the sticky....
Does anyone have a 4k stall tune for an obd1 4l60e I can have a look at to compare?
Car I am building for a guy has a 383, 468 cam, vig 4k stall, 315/17 tires with 3.42 gears.
Anything close to that would be great. I am having issues with the car shifting on a brand new built trans.
Tunercat .bin file would be great!
Thanks in advance....
jimpackard@ yahoo dot com
Old Nov 2, 2010 | 08:48 PM
steveh's Avatar
Re: Tuning for 4k stall.
Do you have a data logger? Without one it's all guesswork.
What shift specs are you shooting for?
And I read the sticky too, and decided NOT to use it!!!!!
I have been dialing my trans shift points in via Datamaster logs, it shows me exactly what is really going on.
PM me your email. I'll email my 3.42 bin file I use you. Only areas I have played with are cooling fans and shift points. Stock 94 LT1, set to shift a tad early for consistency.
Old Nov 3, 2010 | 04:51 PM
bobdec's Avatar
OP said .
Is it sticking in third till engine is shut off and then back on ? , if so could be 'stall wall' DTC 72 needs to be disabled
Old Nov 3, 2010 | 06:20 PM
slowride94z's Avatar
https://www.camaroz28.com/forums/sho...ght=stall+wall
a lot of this information helped me, if I remember correctly. the part of the sticky about the trans needing two things to shift rpm and speed, with the stall the rpm will get there before the speed is even close
Old Nov 4, 2010 | 07:20 AM
jpack24's Avatar
The problem is it was shifting at a lower rpm than I wanted. Even increasing mph in the tables seemed to get it somewhat closer in rpm. Then it suffered in normal driving mode at that point. I was hoping someone would have had a similar set up to compare files.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
