TunerCat tuning for WOT?
Old Feb 27, 2004 | 02:25 PM
jdizzell's Avatar
Can you tune for WOT with tunercat? I mean can you adjust the afr for WOT?
Old Feb 27, 2004 | 05:04 PM
Hal Fisher's Avatar
Yes. There are tables for exactly that but I am not sure if they are used much (%change to Fuel Air vs RPM at WOT). Appears a negative number would increase air to fuel. I have never used that table, and not sure who has (but I might check it out). It must use readings from MAF and not 02 sensors.
Old Feb 28, 2004 | 12:11 AM
97Z-M6's Avatar
%change to fuel/air ratio Vs cool.temp wot
" rpm at wot
the formula is in the help menu on tuner cat. under tables and look for the to tables above. and in one of these table it has the formula
it is used everytime you punch it. it called PE mode (power enrichment mode. it is a target A/Fratio the pcm tiys to hit when you go wide open throttle. bubt when you go wot if the last blm is above 128 the pcm add that to the preprogramed A/F ratio.
so you need to get the blms correct to accuratlly get the pcm to try and target what you want.
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
whitehooptie
Jul 22, 2015 10:25 PM
