Tunercat Lt1/lt4 Tuneing Program
Old Nov 2, 2007 | 05:47 PM
MADNESS_97-SS's Avatar
I had the tune progamed january 2006 a few months later I noticed a change it in. Iam not sure if anyone else has this edit but if you do; when you start to slow down for a stop does your rev limiter stick at 2000 rpm untill you come to a complete stop. Mines doing that no matter if iam in 1 2 3 4 5 6 gear once i stop the engine runs to 2000k for a few seconds then will drop down to around 1100. anyone else having this problem at all. If so did you fix it or just left it how it is. Iam not sure if i should just take the car back to the place that did it or just find another company to install a new tune ? what do you guys think
Old Nov 3, 2007 | 08:38 AM
jay_lt4's Avatar
a tune can not change once it is programmed to your pcm,, you have some other value coming into play
Old Nov 3, 2007 | 11:13 AM
White96Z28's Avatar
Doesn't sound like a tune issue to me. I'd say you have a good size vacuum leak somewhere or you're pulling in unmetered air. Check to make sure you don't have any tears in the intake elbow and then start going through the vacuum lines looking for leaks...
Old Nov 4, 2007 | 06:35 PM
JoeliusZ28's Avatar
my car does this at about 1500 rpm, and ive read in the past that it is indeed a tuning parameter. The car does it with too much precision to be a leak IMO. if im coasting the engine turns 1500 no matter what (as long as i come from above that RPM). as soon as the speedo gets to about 5mph it comes back down to idle.
I plan on doing my own tuning come this spring so i am going to see if i can figure it out. it annoys me too, i want my car to idle when i let off the gas no matter what.
Old Nov 9, 2007 | 08:54 PM
1997 Z71's Avatar
Does anybody have any input. My car is very similiar. Knock code. Idles high at 1400 at any rolling speed. Come to a stop and 2 seconds later the idle drops to normal. any help greatly appreciated.
Old Nov 10, 2007 | 09:02 AM
1997 Z71's Avatar
Figured mine out last night. Found the conductor to the knock sensor was broken in half but the insulation was intact. The idle is back to normal at arourd 1100 rolling and 800 at a complete stop. Did you do any work on your car around the time the problem started? Good luck.
Old Nov 12, 2007 | 11:22 PM
JoeliusZ28's Avatar
where is this piece you are talking about???
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
whitehooptie
Jul 22, 2015 10:25 PM
