trouble after car warms up
Old Oct 20, 2002 | 02:04 PM
Spoolin GST's Avatar
97 camaro LT1 w/ longtubes, cc306, stageII heads, 6 speed
4 weeks ago i began the install of ported lt1 heads and cc306 cam. we droped the motor to do the work. After the install the car was running perfect.. no missing and it was smooth. ok a couple of days later the car started knocking so again i pulled the motor and found that it was one bad baring.. so i replaced the crank, oil pump, and bearings. ok now the car is back together and it misses after the car warms up. first 5-10 minutes it is perfect after that it falls on its face. I replaced the plugs and wires and even switched to taylor over the tops. i am positive that it is not the plug wires. Also replaced the coil. I dont know what to change next. please help!
Erik
Old Feb 13, 2005 | 10:52 AM
stone1's Avatar
Re: trouble after car warms up
I have the same problem with my car after it warms up...only i have changed the battery, computer, had computer programmed,changed spark plugs, coil, ignition module, radiator. But still it runs great for 10 minutes, then the engine dies.
Please...let me know what u did to solve the problem on your car. THANK YOU!!!!!
jj71787
Dec 30, 2014 02:15 PM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
