tricking emissions
Old May 18, 2003 | 06:58 PM
in2ta's Avatar
tricking emissions
I have a tricky question. I know that if you take your cats off it will pull a trouble code and can cause you to fail emissions and if you put on 02 simmulaters it lies to the computer and no codes come up therefore you pass. Can you build your car emmisions illegal and still pass emissions if you have your computer programmed to not reconize the codes or will the test seek it out and find what you are running? could you still use o2 simms and lie your way out of it. I base this question on OBD2 testing
Old May 21, 2003 | 11:01 AM
quicksilver97ta's Avatar
You will fail if any of the emissions equipment is disabled in the PCM. The new plug-n-play OBD2 emissions testing is just that, they dont actually sniff it, just rely on your rear O2's. Sims work just fine.
Old May 21, 2003 | 10:14 PM
in2ta's Avatar
So if i put in a cam and it totally made it illegal I could pass if I stuck simms on there. And how do i get a pic of my car on here like you did?
Old May 21, 2003 | 10:18 PM
in2ta's Avatar
can I have it programmed were the codes are there but they just show any trouble or can they only be erased
Old May 22, 2003 | 08:27 AM
For the pic you have to get an "avatar", there are instruction somewhere on this board, check user cp.
For OBD2 testing, I actually found the proceedure online, they rely on your PCM for all emissions data. It must be there though, it is logged in the memory so clearing the codes, unplugging prior to testing, programming things out just wont work. This data is logged durring a driving cycle. The only thing they start the car for is to visually check the SES light to make sure its off.
walt355
Mar 16, 2016 09:35 AM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
alphaauto
Jul 26, 2015 04:40 PM
