Transmission Tuning Tutorial
Old Jun 15, 2010 | 08:43 PM
  #76
93v8clone's Avatar
i dont have a r.p.m window .its only by speed , i have a performance column and a normall column both have a w.o.t speed rating . bein a camaro and i dont have a perf shift button i should use the norm mode im guessin
Old Jun 15, 2010 | 09:47 PM
  #77
aifilaw's Avatar
... you will note that there are two different tables, kickdown mode by RPM, and kickdown mode by mph... both of these must be met in order to shift... chances are your mph are just fine and the rpm table is too high, it may be the other way around, but not usually.
as far as the other tables regarding normal mode, performance mode and cruise mode... yes you want to do normal mode.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
thenewkid
Apr 12, 2015 07:42 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Jazsun
Dec 29, 2014 12:14 PM
