TPI 165 $32 and $32b compatability
Old Jul 1, 2004 | 11:20 AM
robertf03's Avatar
I'm getting ready to burn a chip for an 88 TPI 350. just turning off some error code flags. In the past I've done several '747 TBI chips using a hex editor and the ECMGUY's PDF document. I downloaded the document for the '165 but after noticing that some of the addresses didnt match up, and looking on the tunercat definition files site I found out about the #32b chips.
Now I can download plenty of $32 .bins off the diy-efi site, can I use a $32 bin in an ECM that originally had the $32b? If it will work, is there any downside to doing that?
Old Jul 1, 2004 | 12:17 PM
onefastgta's Avatar
Once you burn the chip, the old calibration is gone. Most guys will upgrade from 32 or 32b to $6e, but you have to get rid of the cold start injector and tune it some. I don't know what changed between the 32 and 32b, but it shouldn't matter. The 165 ecm is still the same. I even thought of going to the 32b just because some of the fueling tables are not in $6e and are easier to adjust.
Old Jul 1, 2004 | 01:31 PM
robertf03's Avatar
ok, just wanted to make sure all '165 ecu are made the same.
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
4586
Dec 31, 2014 02:21 PM
