Torque Management
Old Dec 7, 2003 | 01:29 PM
the1turkey's Avatar
Torque Management
IS it necessary to remove Torque Management when I have my new TCI 3500 TC installed
Old Dec 7, 2003 | 01:38 PM
Aklaim's Avatar
I believe so.
Old Dec 7, 2003 | 01:59 PM
MARSTAUT's Avatar
Is it possible to remove it without LS1 Edit?
Old Dec 7, 2003 | 02:01 PM
Aklaim's Avatar
No it is not.
Old Dec 7, 2003 | 04:28 PM
the1turkey's Avatar
ok i guess thats another 50 bucks i have to spend
Old Dec 7, 2003 | 04:30 PM
ULTIMTEORANGESS's Avatar
id have it removed.major difference,firms up your shifts.
Old Dec 7, 2003 | 07:58 PM
V6toZ28's Avatar
No, you do not have to have it removed. It makes a minor difference in your track times - maybe .05 - and no difference in around town driving. And it does not "firm" up your shifts ...
Old Dec 7, 2003 | 08:09 PM
how come mine shifts harder? guess im imagining it.
Old Dec 8, 2003 | 01:14 AM
Drew778/94Z's Avatar
You can get it remove with a Predator, talk to James@RWTD.
Old Dec 8, 2003 | 01:30 AM
RS Dragster's Avatar
You want it gone, because it regulates your line pressure. I know a guy from P'Cola that didn't take it off when he put a TCI 4000 in, and the computer thought it was a stock tranny slipping, so it upped the line pressure so much the thing went BOOM!
Definately get her GONE
Old Dec 8, 2003 | 11:42 AM
V6toZ28's Avatar
TM doesn't have anything to do with line pressure.
Originally posted by RS Dragster how come mine shifts harder? guess im imagining it.
You weren't imagining it. You just don't understand it ... TM pulls timing from the engine. During shifts, when ASR/TCS is engaged and also from what I've been told, when ABS engages ... it does nothing to the tranny per se.
What you're describing as "firmer" shifts is the automatic equivalent of power shifting in a manual ... if you stay in the throttle during a shift it will feel "firmer".
People were putting high stall TCs in these cars for years without removing TM and without problems ... then LS1edit came out and someone decided to remove TM and picked up a little ET at the track ... so everyone jumped on the bandwagon.
So now 90% of the internet community, who has limited knowledge of what TM is or what it even does, is perpetuating the myth that TM "must" be removed if you are running a high stall TC ... even worse you'll damage your tranny if you don't ... when actually the opposite is true ...
Old Dec 8, 2003 | 09:43 PM
the1turkey's Avatar
thanks for all the replys so will there be any noticable gains with it off then on
Old Dec 8, 2003 | 11:27 PM
V6toZ28's Avatar
I have 2 PCMs ... one with and one without. Other differences in the PCMs aside; I would say eliminating TM is worth about .05 or half tenth in ET ... I don't run it on the street and don't bother with it when I'm bracket racing ... 3 or 4 times a year I plug it in, when I'm doing heads up racing and making my max effort ...
Old Dec 9, 2003 | 11:04 AM
boomcase's Avatar
To Put it simple , It pulls out Timing when the tranny is shifting Gears.
Old Dec 9, 2003 | 08:06 PM
MISOMWS6's Avatar
Also I see you have a '98 so its not as bad as the '01 and '02 models. TM has affected my car only like 3 times (not shure why no TC or big mods) but it seems on a hard launch it would pull good for a few seconds then just fall flat for a second and pick back up?? I only assume this is TM never checked it with edit or any other program
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
