Third Gen Computer Tuning
Old Jan 27, 2005 | 02:28 PM
TurboSteve's Avatar
I have a couple of questions i was hoping someone might have a some answers for.
Is there any difference between a chip for an automatic and a chip for a standard shift car? Can one be modified to work with the other transmission?
Anyone know what the stock injector pulse width should be on a 1989 350 car?
What's the difference between a .ecu file and a .bin file?
Old Jan 27, 2005 | 05:26 PM
Doc99SS's Avatar
Re: Third Gen Computer Tuning
There is no set PW. The PW is calculated by the ECM and could be just about anything, dependent on several input parameters.
I think that the .ecu file is the actual computer code in the ECM. I know that the .bin file is the file you edit when using TunerCat to tune your 3rd gen OBDI car.
Old Jan 28, 2005 | 04:33 AM
SABLT194's Avatar
The bin file is the binary file (1'ss and 0's) that the ECM actually uses. An ECU file is a protocal or template file that is used for Tunercat, Tunerpro, and a host of others to make it easy for end users like us to edit binary files. Each different ECM (like $EE lt1, $8D TPI, etc) Mask will need a different ECU file
Old Jan 31, 2005 | 05:06 PM
91Z28-350's Avatar
Yes and yes. There are no code variances, just parameter differences from what I've been able to discern. The changes are numerous.
Old Feb 3, 2005 | 11:44 AM
JamesY's Avatar
Not to jack thread or anything but is this on a stock ECU that you guys are tuning? I have been looking around for information and seeing if it is possible to tuen my 2.8Ls ECU if I get it running again, would keep me busy until I had money for the swap I want
MadMav
May 25, 2015 09:35 PM
ChrisFrez
Mar 22, 2015 07:00 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jazsun
Dec 29, 2014 12:14 PM
