tachometer problem.... help!!!!?
Old Jul 9, 2005 | 01:13 PM
Raven02TA's Avatar
ok, to make a long story short just swapped my 02 motor with a somewhat built 99 346 engine, I know that the only Sensor difference or so im told is the coolant temp.
now...... for my problem
got the car together and took it out. Car runs fine. like it should no missing and even at WOT the car hauls *** in many different ways. with no issues. my only problem is the RPM gauge is not working at all. it will jump up at start up to 0 rpms (only off the column) otherwise it wont move. anyone ever have this issue after swapping a motor? or could it maybe be one of the sensors that are different signal wise to the tach?
any help would be greatly appreciated THANKS
incubus454
Jan 10, 2004 08:34 AM
shwine617
3rd Gen / L98 Engine Tech
14
Nov 4, 2003 12:14 PM
N2OpwrdTA
Oct 23, 2003 10:00 AM
87_camaro
V6 Tech
Mar 24, 2003 06:15 PM
bblue99z
Nov 25, 2002 09:21 PM
