Stumbling problem, extremely rich. Why??
Old Aug 17, 2002 | 12:01 PM
slimdawson's Avatar
Question Stumbling problem, extremely rich. Why??
It is a 96 Lt1, obd1. Stock motor other than headers and exhaust and Moroso CAI. Stock program.
I pulled the plugs and they were black. I have been using Freescan and PCMComm. I am seeing BLMs always below 128. Cruising they are 108, the lowest they can go. I thought that BLMs were stored and when the car goes to a particular cell, it uses those stored values. I am noticing that if I am cruising and they go to 108, I can hit the throttle and send it to another cell. Once I go back to cruising, the BLMs start at 128 again.
If I slightly accelerate, the BLMs will go down. So it seems like fuel is being pulled everywhere.
I have disabled all emissions controls via Tunercat and removed equipment.
The car will stumble after after reaching operating temp(160) under load and low rpms. Also, it has slightly popped back through intake only twice that I can remember. The car runs great at WOT above 2k and the motor is in good condition.
I have yet to check fuel psi but I leaning towards a stuck closed fpr or sticking injectors. I had problems with them when I first tried to get the motor running. I had to tap on them because they were locked up. BTW, anyone know of an injector cleaner that actually works?
Thanks in advance, Mike
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.65@84.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
Old Aug 17, 2002 | 10:00 PM
Ed_H's Avatar
Post
The only injector cleaner (I know of) that actuall works is Techron, or is it Techtron. I can spot the bottle a mile away, it's black, and usually retails for around $6. Someone posted a Consumer Reports type ad a while back that showed this was the ONLY injector cleaner at most auto parts stores that actually works.
Old Aug 19, 2002 | 01:01 PM
slimdawson's Avatar
Post
Thanks, I will pick some up tonight. Worth a try.
Old Aug 28, 2002 | 12:57 PM
slimdawson's Avatar
Post
Tried the cleaner but it did not help.
Also, checked fuel psi and it was good. Any more ideas?
Old Aug 28, 2002 | 02:24 PM
Hal Fisher's Avatar
Post
Both sides? Man, 108 at cruise is really bad. You check for an intake or vacuum leak?
Hal
Old Aug 28, 2002 | 08:51 PM
JSK333's Avatar
Post
Is it only stumbling after it warms up? If so, there is a chance that your O2 sensors need replaced.
They may be falsely sensing a rich condition and pulling the fuel is making you run lean, etc.
When was the last time the sensors were replaced?
Solomon
What's life all about?
Silver '95 Camaro Z28 M6: 14.3 @ 98.7 - With problems, but will improve!
White '90 Cadillac deVille: 16.3 @ 81.4 - Not likely to change soon.
Learn the basics of tuning your OBDI LT1 PCM!
Old Aug 29, 2002 | 12:06 PM
slimdawson's Avatar
Post
As for the intake leak, I thought the Blms would be higher than 128 if that was the case.
It progressively gets worse as the car reaches operating temp. I replaced one sensor 7k miles ago and they are both pretty close to each other so I figured the sensors weren't the problem.
Old Sep 6, 2002 | 04:13 PM
toddlsf's Avatar
Post
I am having the same exact problem. My car runs smooth as can be, but then as soon as it hits about 160 degrees or so, it starts missing. It is a slight miss that you can only really feel on a smooth road. I've tried a few things also, but can't come up with anything. Just recently though, my car is hard to start. I wonder if it is a problem with the injectors. Someone on another post mentioned that they had trouble starting the car because the injectors were actually leaking a little when the car was shut off. Then, it would flood a little when trying to start it. I wonder if our injectors are actually leaking a little while running at a low RPM. Mine pulls great until I'm going about 60 with about a 10 percent TPS.
Sorry about the long post.
Todd
Old Sep 6, 2002 | 06:20 PM
Hal Fisher's Avatar
Post
As long as you have injectors that still have their retaining clips on I believe you could check for leaking (svo and others don't allow installation of the clip so don't try this with those). Just pop the rail up a little and turn the car to run (not start). I believe the clips will not let them pop out of their sockets (pull on them to make sure before you try this). I have never tried this so just blip the key to the run position then check.
Hal
Old Sep 6, 2002 | 06:26 PM
Hal Fisher's Avatar
Post
Also, one thing that strikes me as odd is that the tables should correct themselfs and go to 128 after block learn corrections. If this is true then why does it stay at 108?
Hal
Old Sep 7, 2002 | 10:54 AM
slimdawson's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Hal Fisher:
Hal
</font>
Yes you can do that with the fuel rails, and it is in the service manual as well.
I thought the tables remain constant and the blms just compensate for what is needed. I don't know for sure though.
Anyway, I think I am going to replace the Opti, coil, wires and plugs and see if that cures the problem.
Old Sep 7, 2002 | 11:51 PM
stevil's Avatar
Post
I have the same exact problem... here is my LT1 Tech post on it...
I have already tried a new Opti, coil, and new plugs. Wires are next on my list, even though they are visibly OK... they aren't burned, no arcing... they are Taylors, I may have cracked the core wire trying to get Opti boots on .).
And of course that may not fix it either... Just letting you know it wasn't my Opti (*hint* try a few other things before the damn Opti!)
I don't think its ignition related though. I've tried checking for exhaust leaks, sometimes I hear a little something... but I don't see anything.
FormulaV8.com · 1994 Formula · A4 · 3.23
13.45 @ 102.5 MPH w/ 1.9 60' | 267 rwhp | 307 tq/lbs | 3535 lbs
"I know for a fact he is NOT an Easter bunny"
[This message has been edited by stevil (edited September 08, 2002).]
Old Oct 1, 2002 | 09:26 AM
toddlsf's Avatar
I finally fixed my slight miss at 60 mph and my hard to start problem. It was my adjustable fuel pressure regulator. It was actually leaking fuel through the vaccuum line. When it was running, it would allow it to run a little rich. When I shut it off, the pressure would bleed the fuel through the vaccuum line into the engine and let it flood. I've been fighting this since I got the car running, and now I've just got the stock regulator on it. The bad one was an Aeromotive, but don't know if I'll put one of those back on it. I know there are other alternatives to Aeromotive.
Todd
Old Nov 2, 2002 | 12:35 AM
slimdawson's Avatar
Yeahhh! Replaced the optispaz and coil wires and it fixed the problem. It is fun to drive again!
Old Nov 2, 2002 | 08:12 AM
superlund's Avatar
Call Aeromotive on that bad AFPR. I bought one myself & had the same problem. They fixed mine for free & told me they had changed the type of rubber used in the diaphram. They will try & blame it on Alchol in your fuel at first. I had mine on the car for only a month though. I did a search on this site using "Aeromotive" as a key word & found other posts of the same problem.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
93SS
Wheels and Tires
May 20, 2015 06:33 AM
