Stock LT4 File OBD1
Old May 31, 2008 | 02:49 PM
FallonRacingInc's Avatar
Stock LT4 File OBD1
Since some are so quick to say impossible or act asthough anyone who makes posts doesnt know anything, i will spell out what I am looking for a little bit better.... Sorry for the confusion
Title : Stock LT4 File OBD1
Looking for a LT4 tune in OBD1 format.
Originally Posted by FallonRacingInc
I need a stock LT4 Tunercat file that I can flash to my OBD1 computer. Even a slightly modified file should be fine (headers exhaust...). Let me know if anyone has anything
-Kevin
I have a 96 Corvette LT4 with some bolt ons (Full exhaust, K&N)...
Im converting it to OBD1...
The OBD1 computer has a Stock LT1 tune...
I can flash my new OBD1 PCM with Tunercat...
I cant not see what the maps on the LT4 OBD2 PCM, as I have no tuning programs for OBD2... (if I did I would simply use those values to tune the OBD1 PCM...
I would like to see if anyone has a LT4 running OBD1...
If you do, or have a setup similiar, could you send me the file?
Old May 31, 2008 | 06:18 PM
jay_lt4's Avatar
stock LT4's are obd2, they came as a option in 1996 vettes
Old May 31, 2008 | 06:35 PM
I know (and also came in a few 97 Camaros), I own a 96 LT4 Corvette... but Im converting it over to OBD1, so I would like a base LT4 map to start off with to flash the PCM with
Old May 31, 2008 | 06:37 PM
Well, you can't flash an OBD-I tune to an OBD-II computer. How are you going to overcome that?
Old May 31, 2008 | 06:44 PM
Im going to be using a OBD1 PCM
Old May 31, 2008 | 09:44 PM
Oops, I meant the opposite. You can't flash OBD-II > I. The LT4 tune will be OBD-II. So, how are you going to do that, again?
Old Jun 1, 2008 | 05:00 AM
sbs's Avatar
sbs
As they tried to tell you - no such thing exists.
Just start with a 94-95 LT1 vette bin.
p.s. the place to find vette bins is not on an F-body site...
Old Jun 2, 2008 | 12:05 PM
kgkern01's Avatar
If you were to get an OBD2 LT4 file, could you not compare it to an OBD1 LT1 file and make the timing, fuel, and other adjustments, to make it as close or equal to the LT4 as possible?
I would like to see exactly what changes GM made to the tune on the LT4 as well since it is 'basically' a 4-bolt, heads/intake + 1.6RR LT1.
Old Jun 2, 2008 | 06:50 PM
Thats exactly what Im looking for. Im sure someone has converted OBD2>OBD1 with an LT4.
btw, Im well aware that an OBD2 tune can not be flashed to a OBD1 PCM.
just checking to see if anyone has a base tune I could start with.
Old Jun 2, 2008 | 09:56 PM
Sure, you could compare the files using the software that each would need to look at it. Manually looking at the files and copying data one to another. Your original question was about flashing, though.
Old Jun 3, 2008 | 12:28 PM
see my first post... i edited it
pimpss96
Feb 12, 2015 01:28 PM
NewsBot
Feb 6, 2015 05:00 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
