Stall wall
Old May 16, 2007 | 01:47 PM
kline454's Avatar
Stall wall
I need to get my pcm tuned, to get ride of my stall wall problem, everthing is good with the tune besides the stall wall, I have a cable and labtop i just need to find someone i can email the tunes to that can fix this, ANYONE? I tryed geting a hold of madz28.com where i got my mail order tune from but he hasnt got back to me and i need this ASAP.thanks kyle
Old May 16, 2007 | 01:59 PM
MichiganSkip's Avatar
If you have TunerCat, go into the ECM Constants table and scroll to "Vss Diagnostic Enable Min" and change the rpm value to on that is above your converter stall value. Worked for me! There is actually a few threads discussing this problem.
Hope this works for ya.
Old May 16, 2007 | 02:40 PM
kline454's Avatar
Thanks but i dont have any tuning software.
Old May 17, 2007 | 06:40 AM
kline454's Avatar
Well madz28.com sent me a fix but he didnt change the vss min rpm table he changed shift table it was set to shift 1-2 and 28mph and he has it set at 1mph, but it seems to work does this sound right?
Old May 17, 2007 | 06:42 AM
Some do others don't.
Old May 17, 2007 | 08:50 AM
Airbornec507's Avatar
This means that your car now shifts off of rpm rather than speed. check the hot/kickdown rpm threshold values. I bet they are higher than the previous settings.
I usually change the vss in the constant tables as well. But hey if it cleared the problem up than that's all that is needed.
Old May 17, 2007 | 11:58 AM
kline454's Avatar
well just tryed it again and same problem still!! hit rev 1-2 shift then loses 1-4 , till you shut off the car then its good again.
Old May 17, 2007 | 12:16 PM
kline454's Avatar
will changing the Vss min rpm table fix this??
Old May 17, 2007 | 08:43 PM
jay_lt4's Avatar
i sent your files back to you, give them a try, let me know if you want the shift rpm's raised
Old May 19, 2007 | 02:05 PM
jay_lt4's Avatar
any luck??
Old Aug 17, 2007 | 03:23 PM
ssean92's Avatar
been looking in tunercats and dont see the min vss rpm???
Old Aug 18, 2007 | 06:05 AM
jay_lt4's Avatar
file sent back to you,
Old Aug 18, 2007 | 08:04 AM
What version of Tunercat? 2.11 has it.
Old Aug 18, 2007 | 11:46 AM
ssean92's Avatar
only have the trial version of rt tuner, havent bought it yet
Old Aug 19, 2007 | 09:42 AM
Black97SS's Avatar
I have an M6 car but I took a look in tunercats and that table is there. If you are using the trial version it comes with the $42 definition file. I looked at a test bin with that definition file and didn't see the "Vss Diagnostic Enable Min" table. You'll have to buy the $EE definition file for $20 to be able to use tunercat with your car. I think you have to buy tunercats before they'll sell you the $EE definition file, I could be wrong about that though.
