SPLIT BLM'S...SOLVED.
Old Aug 12, 2002 | 01:52 PM
  #16
Fred94LT1's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Dr.Mudge:
Fred, your mentioning BLMs but the post is about IAC counts not BLMs, the IAC should not affect your BLMs at all. Am I missing something? Is it your BLMs that are randomly haywire? I have heard about measuring the voltage output of the IAC but never the resistance???
Carl, there is an IAC circuit not just in the TB but throughout the intake manifold, it was there to be used. Some people chat and drill a small hole in the TB blades, or crack them open like you and I did, but that is a hack solution. My cam was big enough that people with smaller cams should not have a problem getting thier stuff to work, I got my IAC counts down to the 40s with some fixing of the TB and no blade opening at all, that is a plenty fine IAC count and nowhere near the cieling of 160. I had 160 IAC counts when the TB was freshly installed and it would not idle on its own without cracking the blades open or revving the engine a bit, so I know of the problems. I will try to hunt down the IAC circuit pictures and post them later.
</font>
As far as mentioning BLM's at idle I added that because My BLM's were getting way out of wack at idle. It was running real lean on one side and rich on the other. I thought the two might be related. Carl is adjusting his throttle stop with success for idleing. According to my Haynes manual the resistance on that little step motor(IAC), should be between 40-50 OHMS. OHM readings between the a and b and c and d terminals. That is only to measure the resistance of the motor windings. BTW, My pintle was stuck and wouldn't move.
Fred
Old Aug 12, 2002 | 02:58 PM
  #17
carl97ss's Avatar
Thumbs up
Hey DR. As odd as it sounds, as i stated earlier, the IAC counts at idle affect the idle split BLM'S. I know where ya are coming from w/ the idle air passages thru the intake. All i can say, the shutting down of the throttle plates and having all the idle air going thru those little holes at the mouth of the intake manifold runners, has never worked for me.
'97SS, More Performance 396, AS&M cold air, Grotyohann LT, SLP 2ODL muffler, Magnacor, PCMFORLESS PCM, LS1 twin piston calipers, KVR crossdrilled and coated rotors, SLP stage II w/ KYB AGX, 6M, Star Stage II.
Old Aug 12, 2002 | 09:18 PM
  #18
Dr.Mudge's Avatar
Post
Well, you do have a 396 and I have a 350 so who knows, but with my cam and 40ish counts, I figure anyone can do this, and I didn't open up my 58 much more than stock.
Here are some goodies, compliments of Christian:
<font face="Verdana, Arial" size="2">I'd say the split BLM and IAC are LT1edit issues for sure, never be afraid to share stuff, because you're rarely alone.
The actual IAC passage that needs to be opened is the very small hole pictured here:
http://carprogrammer.com/Z28/PCM/TB/DSCF0706.JPG
I opened it to look like this:
http://carprogrammer.com/Z28/PCM/TB/DSCF0699.JPG
Don't mess with the actual IAC passage. Several other stock pictures here:
You basically want to get the air flowing through the triangle pictured here:
http://carprogrammer.com/Z28/PCM/TB/DSCF0704.JPG
And less air in the intake plenum, since rumpy cams introduce reversion like a ****.
Keep me posted,
-Christian
Check out Als' updated page on the IAC passages- really good!
http://members.***.net/chipsbyal/idle.htm
</font>
[This message has been edited by Dr.Mudge (edited August 12, 2002).]
Old Aug 12, 2002 | 09:19 PM
  #19
Dr.Mudge's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Fred94LT1:
Fred
</font>
Ooooooh, ok. If you've got a 'biggy cam', this is why many people give up on close loop idle and run PE up to 1200 RPM in the PCM, then make sure the AF is good on the dyno and you have closed loop operation like a normal rig the rest of the time.
Old Aug 12, 2002 | 10:56 PM
  #20
Dan K's Avatar
Post
UPDATE: I just got back from a ride. The problem returned... I saw Rin readings as low as 88 and Lin readings as high as 185 on the scan master. It will suddenly go back to 128 on Rin and Lin for a few minutes then it gets lean on one side and rich as heck on the other. [This message has been edited by Fred94LT1 (edited August 11, 2002).]</font>
Fred,
The car I've been working on that has split blm's at idle does the same thing. For about 30 seconds the blm's will be within 3-4 of each other and then one will start to drop and the other will rise. MAP, idle rpm, and timing doesn't change but the blm's start to go crazy. On one side the long term will drop to 108. About 10 seconds later the short term will rise and go over 128 and then the long term will start to head back to 128. At the same time the other bank will be rising up to 140 or higher and after 10 or 15 seconds the short term will drop below 128 and the long term will start to drop again.
Then they'll both sit at 122-126 or so for about 30 seconds and the process will start all over again.
I guess we're going to try and drill out the passage that Dr. Mudge shows in the post above and see if that helps at all.
Then try to adjust the IAC again.
Old Aug 13, 2002 | 09:31 AM
  #21
carl97ss's Avatar
Post
well at least you know your sensors and PCM are working correctly from the standpoint that the short term and long trerm fuel trims are trying to do what they need to do. I had that issue and in my application it turned out to be slow O2's and/or the non-GM O2's. i replaced w/ GM O2's and that swinging back and forth stopped. FYI...the electrical tests of the O2's were fine. scanner really did not show a slow condition.
Dr mudge, if you get a chance, email me about your mods and cam you use. thanks!
[This message has been edited by carl97ss (edited August 13, 2002).]
Old Aug 13, 2002 | 05:21 PM
  #22
Dan K's Avatar
Post
These are GM O2's. The car is a 93 and we converted it over to heated O2's using all GM parts. Sure wish I could figure out why it does this.
Not sure if it hurts anything or not though. I guess I'll just adjust the idle stop screw until the O2's are about as even as they can get.
Old Aug 13, 2002 | 07:37 PM
  #23
Dr.Mudge's Avatar
Post
Dan, I dont imagine stock speed density cars have that problem, do you have any mods though that might explain it?
Carl, pretty simple, Heads, SLP shorties, K&N intake cutout, proprietary cam similar to cc306 but better lobe profile, without getting into every single part thats it.
96speed
Feb 2, 2003 06:15 PM
Northwest94Z
Dec 23, 2002 12:34 PM
texanmutt
Nov 3, 2002 10:35 PM
Dave 96TA
Oct 8, 2002 09:04 PM
Dan K
Aug 28, 2002 12:06 AM
