Speedo recal LT1 A4 -93 questions
Hi..
My friend whant to change gearing from 2.73 to 3.73 on his Trans Am A4 -93
What is needed to get the speedo/ECM to work correct?
Is it controlled by the ECM? or is it gear driven?
I already have TC+burner and so on... and was lookin at the $DA3 def.file there is somehing called "Instrument Panel VSS Pulse Divisor" and "Road speed constant".
My guess is the the Pulse divisor should be multiplied with 3.73/2.73 correct?
/N.
/N.
Re: Speedo recal LT1 A4 -93 questions
Since it's an A4 car you can swap out the transmission drive and driven gears with the proper ratios to correct the speedo. Unfortunately, I don't know what the part numbers are for the 3.73 set. Try a search on here or the speed density board link in my sig. You should come up with them.
Jul 4, 2005 05:00 PM
