Shift firmness question??
Old Jan 25, 2005 | 10:27 AM
94Zpower's Avatar
I have a pcm for less tune in my pcm which includes the firmness adjustment set to firm and now my new trans is being built with a shift kit do I need to send it back to get re adjusted to the stock setting??
or I do have a B&M shift plus switch that I never installed will that do the trick of putting it back to the stock setting?
Thanks!
Old Jan 25, 2005 | 12:42 PM
DarkHorse's Avatar
Re: Shift firmness question??
If you don't have a cable/laptop then yes you will need to send it back to Bryan to have the line pressure and whatever else he adjusts set back to stock.
Old Jan 25, 2005 | 09:47 PM
Sweetred95ta's Avatar
Drive it first. I had a ton of line pressure and a shift kit and I loved it. Leaving a stop light at 1/4 throttle and chirping hard 2nd's. It was cool. I lost some of the firmness when I put in my stall, but now it is perfect. So if you plan on putting a stall in, leave it. Just my opinion, I'm not sure if it can do damage to anything but the rearend .
Benji
Old Jan 25, 2005 | 11:46 PM
DarkHorse's Avatar
It's seems to have damaged your transmission if your sig is correct. Increasing the line pressure is an old debate around here - I suggest researching it. For what it's worth I had mine bumped to 115 for about 20 passes at the track and a couple months then dropped it back to 95. I have no valve body kit yet.
Old Jan 25, 2005 | 11:58 PM
The racing damaged it. I was fine until I blew the motor up and let it sit for 6 months. Then got the car running again and now it doesn't shift when it should. I drove it with the line pressure up for a long time. I heard there is a vacuum actuator (sp?) that actually makes them go bad.
Benji
Old Jan 26, 2005 | 07:04 AM
94Zpower's Avatar
well the tranny I am having built is a race trans so I think it could handle more than stock, but I will ask the builder that question, my question was really can I switch it down a notch with the B&M or should I send the pcm back in for the adjustments??
Thanks guys!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dale3in98
Feb 14, 2015 12:18 PM
jb4xx
Feb 2, 2015 10:00 PM
cmdeshon
Dec 27, 2014 10:06 AM
