service engine light question
I have a 2000 SS and just swapped a LS6 intake on it and now I have a service engine light and a service vehicle light because the EGR tube isnt hooked up to the intake anymore, I tried to plug it up and reset the computer, but the light is still on. Anyone know how to make it go away? Will it retard the timing if its on because of the emissions code? The car definitley runs way better, but I'm not sure if its loosing power from this light.
Matt
Matt
Re: service engine light question
You cannot just plug it for the PCM is still assuming your engine has one and will also fail the built in smog tests and trip errors.
You need to tune the PCM and turn off the EGR as the newer models do not have them.
Matt
Matt
Jan 5, 2015 07:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Jul 4, 2005 05:00 PM
