Pulling timing under heavy load... is it abnormal?
Old Sep 11, 2007 | 03:19 AM
v7guy's Avatar
Was scanning my car.
While taking off from a light in first, even when I was getting on it everything read ok. When cruising in third at 1200 rpms or so and then getting on it I'd start getting an increasing knock count and spark retard, at the worst the spark retard was at 4.7 degrees, but this was extreme and rare.
Is this something I should be worried about? Something I can change? Or is this normal?
Old Sep 11, 2007 | 06:31 AM
MEAN LT1's Avatar
Im not sure what your supporting mods are but most likely it is faulse knock. Only way to make sure is to put some higher octain fuel in the tank and scan it again.
Old Sep 11, 2007 | 08:20 PM
mzgp5x's Avatar
I zeroed all the knock tables with LT1 edit. Timing was being reduced with all the added mod noise. (383-D1, RR's headers, etc).
Old Sep 11, 2007 | 08:32 PM
aknovaman's Avatar
It's not good to totally remove any knock sensing. Would you ignore a knocking rod?
Old Sep 12, 2007 | 06:18 AM
MEAN LT1's Avatar
Theres nothing reduced timing will do against rod knocking. As long as your tune is dead on I see no reason why you shouldnt be able to zero out your knock table.
Old Sep 12, 2007 | 11:23 AM
95Blackhawk's Avatar
Do this and report back. I don't like the suggestion of just zeroing out knock tables.
Old Sep 12, 2007 | 08:32 PM
v7guy's Avatar
I'm not terribly interested in removing the knock function, like I said, I was mostly wondering if it was normal or not. I take it that pulling timing when the engine is heavily loaded is abnormal?
I can take off in second gear and there is no retarding of the timing. When I get on it and spin it 6200 the most retard I get is .4 and no knock count. It only happens when I bog the motor heavily.
Motor is a 97 LT1 EGR! AIR! LT4 KM, ported heads, cam, 1.6 RR, solid motor mounts, poly trans mounts, longtubes. Pretty standard 4th gen.
I'll find some fuel tomorrow and see what I find.
Old Sep 12, 2007 | 11:35 PM
aknovaman's Avatar
0.4 is nothing. Stock tables can pull up to 15 degrees. If the tune is good, you can set it to whatever you want and it'll never get retarded if there is no knock.
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
