possible? MAf to SD
Old Jun 3, 2004 | 12:58 AM
simple's Avatar
possible? MAf to SD
to switch over to speed density while still retaining the flashability of '94+ pcm's?
what would be pro or cons of doing so?
Old Jun 3, 2004 | 12:24 PM
PoorMan's Avatar
I am thinking on doing it. It's easy with Tunercat. Just a check box. I do not think there are any cons to it. Pros; less restriction.
Old Jun 3, 2004 | 01:08 PM
djw's Avatar
djw
There is at least one con that I know of. It is more difficult to tune in SD than MAF. Someone that knows what they are doing will have know problems, but it does take more knowledge so getting a good tune can be more difficult.
Old Jun 3, 2004 | 01:24 PM
PoorMan's Avatar
I was going to try it and log some runs after doing some VEMaster reprogramming to see it has an effect. I am pretty sure most people believe that the VE tables play more into the tuning in SD mode. I will just have too see for myself.
Old Jun 3, 2004 | 09:53 PM
bunker's Avatar
in speed density all it you have is basicly VE tables to reference from, yes slight changes in the VE table make major changes in SD mode.
Old Jun 4, 2004 | 01:06 AM
simple's Avatar
so is it worth it? or....
Old Jun 5, 2004 | 07:43 PM
arnie's Avatar
The more mods (read airflow) the engine experiences, the more viable/worthwhile the SD mode becomes. To put another way, if ya don't max the MAF, the switch then becomes an exercise in alot of extra flash tuning, without a significant improvement in torque output. BTW, the term VE tables includes alot of different maps/tuning variables. This is both good and bad. Good for fine tuning, and bad from the standpoint of alot of tables to go through. MAF is flexible maintaining tune (and emission compliance) with varying weather conditions, SD is not.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
