Is this possible?
O.K. here's the question: Can you remove a program from an ODB2 car and send it to an ODB1 pcm? Or, is it possible to swap pcm's.
I have put in a new motor and it had a custom tune on the pcm, but it was a 96z and I have a '94z. The donor car was an A4 and mine is an m6. I really don't want to send the pcm off to get programed and nobody locally seem to know if this is possible. Thanks, Chris |
pcm switches are possible, but most people switch from the II to I beeause of ease of programming. If you do put the II in the 94, im almost 100% positive the ses light will be on because im pretty sure II cars have 2 o2 sensors, one before the cats and one after. I could be wrong there thou. But many of the options are different. Also you might run into problems being the donor is an A4 and now u have an M6
What I would do is, get yourself a laptop, tunercat, and tune the OBDI yourself. If you need someone to make up the program file for you, contact madwolf, he is currently doing my programming and has done many others. |
actually OBD2 cars have 2 CATS and have 1 sensor before and 1 after on both CATS making a total of 4 O2 sensors. But they can be disabled with LT1_edit:)
What about the Crankshaft Position Sensor? OBDII Has that as well can that be disabled?
Originally posted by JOE96Z28SS What about the Crankshaft Position Sensor? OBDII Has that as well can that be disabled? |
I'd imagine it would be easier to just put the sensor on! using the FTC and HED off of a 96
