Po 171- po 174
Old May 1, 2010 | 07:25 PM
96 SS 1424's Avatar
Po 171- po 174
I have a 96 camaro ss. Im getting codes po 171 and po 174. I googled it, and it said that it was a lean condition. What could be causing this condition ?
Old May 1, 2010 | 07:55 PM
dangalla's Avatar
o2 sensors
a lean condition
wiring
how does it run?
you could have a vacuum leak, does it idle ok?
have you recently done any work to the car?
Old May 2, 2010 | 08:58 AM
96 SS 1424's Avatar
The car is hard to start when it sets for weeks, but starts fine the rest of the day. When it does start it runs and idles good but when I revved it up to do a hole shot it fell on its face.
Old May 2, 2010 | 09:50 AM
With both sides running lean, its most likely something affecting both banks simultaneously. Check the fuel pressure - could be low pressure/dirty filter. Check for a tear in the inlet elbow, between the MAF sensor and the throttle body. When was the last time the MAF sensor was cleaned?
Old May 2, 2010 | 12:55 PM
96 SS 1424's Avatar
The elbow is aluminum and the MAF sensor has no screen it has after market ends .
Jan 9, 2013 05:32 PM
99HOSSJOE
Dec 16, 2007 12:23 AM
pimpinphil
Aug 1, 2006 07:38 PM
dregsz
Feb 15, 2005 01:55 AM
95m6
Jul 20, 2004 04:13 AM
