Please help me get my car tuned .
I have a 95 camaro stoked out to a 383 with a votech T-trim . I now have Ported Lt4 heads and intake that is about to go on. The plan is to raise the boost to 10-12psi . I just want to be just my vehicle will be getting enough air to fuel and just be sure everything is running right . I had my initial tunning done by Ed Wright but he said that he is full unto the end of October and after that he might not be doing any more dyno tunning . Any help or advice would be great .
Thank you , Ben
Thank you , Ben
No , I did not ask him if he locked it up i'll call tomorrow . I am changing the heads and intake and going from 3olb to 42lb injectors. I am also adding an Lt4KM and upping the boost from 5lbs to 12lbs . I am fairly new to all this so I really do not know to much on how to prevent the car from detnation or running lean .
Thanks Ben
Thanks Ben
