PCM programming - suggested settings?
Old Apr 17, 2005 | 11:50 PM
00 SS's Avatar
I am going to have my PCM programmed to recalabrate speedo for new gears (just simple settings, not a full blown custom tune). While I am having it reprogrammed, I am going to have the fan turn on for a new 160 degree thermostat, turn off skip shift, remove speed limiter, and delete torque management. I am considering raising the rev limiter if it is safe to do so, what is safe on a stock ls1?
Slp sells a traction control reversal module that turn off ASR until you turn it on. Can you do this through the PCM?
What other PCM programming changes should I consider?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
CARiD
Jan 27, 2015 06:27 AM
thenewkid
Nov 27, 2014 09:41 AM
F(ast)-body
Feb 26, 2003 09:05 AM
