PCM burnt or Trans Bad
Old Dec 21, 2003 | 01:44 PM
LPE Z convt's Avatar
What are some of the things that happen when your trans goes out? I have an a4 and when i try to take off when the trans is in drive it acts like the brakes are on the car doesn't want to move but like their is resistance.... But after it gets moving the trans works normal... Also my speedo reads 110mph when i am only going 30-40mph.... When i pulled the car in the garage everything worked great ..... The only thing i changed were my plugs and reflashed the PCM.... What are the chances of the pcm having to many flashes in it and being bad? The pcm has been flashed maybe 30 times or more and i do have a msd ignition...
Old Dec 22, 2003 | 06:22 PM
PoorMan's Avatar
Why did you flash the PCM? What did you change?
Jeff D.
jackpawt883
Feb 26, 2015 09:04 PM
jb4xx
Feb 2, 2015 10:00 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
