Paging Dan K!!!!!!!
Paging Dan K!!!!!!!
Hey, I was reading this link tonight, and in your first post you talked about IAC counts and setting them for the 10-40 range to help with the "tip in stumble" seen with bigger injectors. I think I may be having this problem, and am wondering if this may be it:
When in low rpm, all gears, as I roll into WOT, I get a split second hesitation. It just cuts, then comes right back. I've logged several of these incidences on datamaster, and Alvin@Pcmforless and myself can see nothing at all wrong with the car. FYI, I've got 30# SVO's and ported heads/224/230 cam. This isn't the same car that you helped me with before, it's my other one. Anyway, does this sound like the "tip in stumble" that you mentioned??
Unfortunately, I can't do anything with the car until I return from the mid east in mid october, but any guidance you could give me would be greatly appreciated. I'm really hoping that this is the problem. I do have my laptop with me with several of my datamaster logs on it that I'm going to take a closer look at.
When you said to set the IAC counts, how would I go about this with tunercat???
Thanks!
Thanks!
Well, by tip in I'm talking about going from no TPS (or VERY little) to 1/4 throttle or so.
You can even feel it just revving the car in park.
It's just this slight hesitation before the engine revs.
Is that what you're experiencing? Doesn't sound like it.
If you want, send me the datalogs and bin file and tell me what to look at/for.
Sorry I didn't catch this sooner...my beeper didn't go off
Originally posted by PoorMan
I really think this can be addressed with the VE tables but have never tested it. All you non believers.
Jeff D.
Jeff D.
Ben
I dont think their is any evidence of if thats true or not. Larger cams have some reversion from overlap and some of this fuel goes back into the plenum and is sucked into a different port. Cause of Split BLMs?? This adds to the rich mixture that many see with cam swaps I believe. Changing the VE tables in the low RPM low MAP regions would seem to help this. I wish I know if someone has tested it.
Jeff D.
Jeff D.
Before I modified my MAF tables (back when I was green) I tried VEMaster thinking that was my answer. With ever iteration of the program, the VE's were farther away from stock with the BLM's still in the exact same area.
I have tested it and I know for a fact VE (on my car, won't answer for yours) is not used.
Ben
Ben
Set them all to 0 or 100 or something and see what happens. Pretty easy way to test.
There have been people that have tested this and have found that it didn't change a thing.
i wouldnt have even mentioned this but i noticed your list of mods. when i installed my 30# SVO injectors, my car did the exact same thing and still does. i installed them before my cam and made all the necessary adjustments like offsets and injector constant. it seems to happen more when the car is cold but the hesitations definitely didnt exist before my injectors were installed.
Originally posted by Fastbird93
How did you alleviate this problem?? I really need to get rid of is since it's a real annoyance.
What I have heard is that the hesitation is caused from the larger injectors, and that a fix would be to program in some more IAC counts. As read from that other post I linked at the top at least. However, I haven't been able to verify this as I'm 1/2 way around the world from my car right now.
cmsmith
Aug 27, 2015 06:37 PM
cmsmith
Aug 20, 2015 07:57 PM
